Hello all. Im an avid reader of these forums for years and love the insight and expertise most of you carry. You have helped me extremely well in the past and hope you can do the same now.
I own a H/K Avr 525 reciever and it has powered a set of cerwin vega speakers. Even though the receiver is rated at 80wpc at 8ohms,,my speakers are rated at 250watts at 4ohms,,it has been powering quite well for some time now and was just wondering does this affect the reciever by powering lower ohm speakers,,4 ohms,,from my receiver which is rated 8 ohms?
I have recently purchased a crown xls 420 amp. It is rated at 400 watts at 4 ohms. I will hook the amp up using my pre-out jacks on the back of my HK receiver thereby bypassing the internal amp of the receiver. However, by doing this does it also relieve the strain i have been putting on my receiver because now the ampage is coming from the crown and not the hk reciever?
Third and final,and probably a idiot question. The crown being rated at 400 watts would blow the 250 watt speakers,how then do you know how far you can go with the volume before "blowing" them? Is their a gage on the crown amplifier that will tell when to stop turning the volume or is this just up to the listener to not crank it?.
Thanks guys.
Thanks guys.
