Originally posted by jmbnyc
Can you tell me exactly (pretty please) how you have it connected and how you do video input switching. Do you have a pc monitor attached or do you use the plasma for both purposes? Why did you choose MyHD over accessDTV? Based on comments from this forum, I was going to choose the access card because of its ability to pause live TV (I have 2 kids under 5 and this is something I need). What do you have your audio card connected to? And how is it connected? Do you use cable, sat or ota? Lastly and most importantly, how is the picture quality for DVD, TV and playback?
HDTV cards, like MyHD and AccessDTV, allow you to pass-through the HD video. So MyHD and the Radeon outputs are connected through a special cable which has a third connection for the VGA display (a projector in my case). I also own AccessDTV but gave up on them a year ago when they fell behind in supporting their software; they are doing better now. I like the MyHD interface but you are correct - only AccessDTV can support pausing live TV. AccessDTV has a horrible file naming convention.
My Cable TV box is attached to my H3D card thorugh S-video as is my external DVD player (H3D has S-video, composite, or you can select component/SDI). I hooked up the SPDIF audio from my cable box to my M-Audio card SPDIF in. The M-Audio, MyHD, and RP82 SPDIF out's are hooked up to an Audio Authority automatic switcher and then to the receiver (which does not have enough digital inputs). With the M-Audio control panel, I can select the internal or external audio sources if needed.
The cable TV PQ is very high for digital channels (including the premium HBO etc. channels) - remember that I "enlarge" the picture through the projector so defects are more obvious. Analog channels are not good but you can adjust the picture. So I use the H3D program for the "normal" high quality sources and have configured Dscaler to darken and reduce the contrast and saturation of the analog channels (eg Fox, UPN).
External DVD playback through H3D using a Panasonic RP82 has very good PQ on my 8-foot wide projected screen. On the other hand, Zoom using the Cinemaster 1.5 filters looks very close.
You cannot use MyHD to output your main video and you still need a primary video card for H3D/DVD/overlay playback. Other programs cannot direct their video to MyHD. The 9700 Pro is expensive and has excellent PQ, but you can wait for reviews of the 9500/9500 Pro to see if you can get those cards for less IF they can deliver the same PQ). Note that the 9700 series does suffer from "occasional" powerup problems (no biggies - even with the RMA'd card from ATI, I need to re-cold boot my HTPC one out of 10 times).
Plus, when you use Radeon cards, you get Cliff's scoped settings that allow you to get a head start in optimizing PQ
