Status
Not open for further replies.
1 - 3 of 3 Posts
I have a H78 but am assuming/hoping this question is valid for H77 and H79 as well.
I have searched all the menu options but can't for the life of me determine how to set the PJ to PAL vs NTSC. I play PAL discs once in a while on my Oppo and rather than using it's PAL->NTSC conversion I would just like to set the Oppo output to 'PAL' and the H78 to PAL. Oppo also has an 'auto' display feature, but not sure if that would work. if H78 is always showing NTSC, then the Oppo might use the conversion anyhow.
So - how does one go about setting the PJ for PAL format?
Originally Posted by brotherman
You don't set it, the PJ auto detects. The tell-tale is the frequency listed (50 Hz for PAL vs 60 Hz for NTSC)
A second good hint is that the sound level of the projector (colorwheel and fans) also go down because of the 50hz vs 60hz.
Daniel.
1 - 3 of 3 Posts
Status
