Status
Not open for further replies.
1 - 7 of 7 Posts
The more I research the Samsung TXN3245FP EDTV, the more I get confused. Since I am buying my First HDTV, I really don't want to break the bank, and this is more for DVD/Gaming than anything.
Now, some places say this tv can accept a 480p/480i and 1080p once hacked, while others say it lacks the circuity to display 1080i images. :confused:
Taken form Circuit City's website:
"Editor's Note: Thank you for taking the time to share your thoughts on this television with us and our customers. Your review about the high-definition capability of this TV prompted us to do some research, and we would like to address your comment about changing the display. While the menu can be changed to indicate that it's in HDTV mode, this TV does not include the computer chip or the receiver that will allow it to receive and decode HDTV broadcasts. As a result, the resolution of this TV is limited to 480p, which is perfect for movies on a progressive scan DVD player. We hope this clarifies the capabilities of this TV, and we thank you again for your comments."
Thank you for your review. Your comments prompted us to do further research by contacting Samsung directly. The TXN3245FP is an EDTV, meaning that it is capable of receiving and displaying a 480p signal. Samsung has service menus with a number of adjustments and settings designed for servicing the sets. Chassis and parts are often shared from model to model however the published features list the exact parts included in a given model. Often there is a universal software package in the service menu that would appear to activate a function or functions--assuming the part is included in the set, when in fact it may not be. Selection changes in the software do not equal changes in the hardware if the parts are not present. Making unauthorized changes in a service mode could also compromise the performance of the set. Any changes in the service menus that are not performed by an authorized technician acting on Samsung's behalf would void the warranty.
By CEA definitions an HDTV has a built in tuner/decoder to receive and display an HDTV picture. An HDTV Monitor is capable of taking the signal from an HDTV tuner/decoder and displaying it in High Definition. Most CRT TVs today are HDTV Monitors. HDTV Monitors do require an optional tuner decoder to take advantage of HDTV broadcasts. An HDTV Monitor does require special circuitry to scan 1080i.
We hope this addresses your concerns, and again, we thank you for your comments"
Now I am really really confused.
Whatever Circuit City told you is incorrect. The TV can and will display a 1080i signal. I have tested and confirmed that this works on the 27" model and the 32" model. In case you have not figured it out. I JUST tried this tonight, and it works like a champ.
Anyway, here are the steps.
Power off your TV
Now on your remote press these buttons
mute
1
8
2
Now turn your TV back on.
You will see the service menu
Go down to video adjust 3
Scroll down to the bottom of this menu
Look for "no 1080i"
Change this setting from 1 to 0
Hit mute again.
Turn your TV off, and turn it back on. Now you can display a 1080i signal!
If you go to your local Circuit City and show them this little trick, chances are they will not only let you preform this experiment, but you will amaze them in the process.
I suggest you start by asking what the screen will look like with a component HD signal applied to the TV. A good sales person will "show" you. Then ask them if you can show them how to "convert" this TV to HD.
The look is priceless...
late
PRO
You must have a PRETTY new model. The one sitting on the shelf at my Circuit City was manufactured in Aug 03 and the option IS there.
Its just the last option on the list, so its off the bottom of the screen. You can select it, its just hard to tell if you actually have the cursor on it.
My opinion is that the option IS still there, except people are confused when they don't "see" the option.
good luck
PRO
I'm not confused. The newer models have completely re-vamped Service Menus as well as less overscan bounce.
TXN3245FP SERVICE MENU OCT. 2003
DEFLECTION
V amp
V shift
H ew
H shift
V linearity
V sc
H parabola
(corner values)
Bow
Angle
eht time
eht threshold
480 OFFSET
1080i OFFSET
VIDEO ADJUST 1
A trio of "Cutoffs" and "Drives" for R, G and B
SUBs for bright, color, contrast & tint
AKB Option …… 1
BLC Threshold
BLC Gain
BlC Time
Sub Sharpness
VIDEO ADJUST .......... 2
VSU …………2
Melody vol
Hb start
Hb stop
Vm gain ……………. 30
Vm delay ………………..9
Vm coring ………………..15
BLE tilt, gain, mode and break
CTI GAIN ……………….. 0
CTI CORING ………………..0
LTI GAIN ……………0
YC delay …………. 2
PIP YC Ddelay
Band pass F …………1
Hi pass F …………….3
VIDEO ADJUST 3
NR OFF VALUE. …….7
NCE bypass. ……………… 0
Gamma mode and correction
BST startpoint and gain
DPWL startpoint and gain
EHT_FC ……………….1
EHT_HP1 ……………..0
EHT_HP2 ……………..0
V-Mute
SCRO Value ………………1
VIDEO ADJUST 4
VIDEO ADJUST 5
VIDEO ADJUST 4_comp
VIDEO ADJUST 5_comp
(All have a couple values such as “MR2M1â€)
OPTION (a6h cch 07h)
CRT 4:3
PIP ......... off
3D COMB FILTER ..........off
BLUE SCREEN
BBE ........... off
EQUALIZER
AUTO POWER
SYSTEM
VIRTUAL DOLBY ...... off
ACS
V CHIP
SUB WOOFER ......... off
NO SYNC MUTE
X RAY
AGC
TURBO EFFECT
BURST SCREEN
LNA OPTION
EXTRA IMPUT: NONE
(most all set to on or off)
RESET / 03-07-19)
CHECKSUM
G2 ADJUST
(both display info rather than adjust settings)
Damn that sucks. I wonder why that loop hole existed in the first place? Showing some love to the customer?
1 - 7 of 7 Posts
Status
