So I've recently become a Hafler fan. (mostly b/c i need clean cheap amps while my main 2 amps are being refurbished ETA 2 months!!!)
My XL280 sounds really good to me. Warm, good low end grunt, not as loud as I wanted so I picked up a relatively inexpensive DH 500. (I know you get what you pay for
The potential issue I am exploring is the amp just doesn't seem to put our 255 wpc. The low end bass is not there either compared to the XL280. The amp doesn't sound terrible but I think something is amiss or maybe the difference in the amps is just that they are different amps?
So my "sophisticated" test is I have a pair of Martin Logan Montage speakers rated at 150 watts and 5ohms. So I would expect this DH 500 to blow them apart if turned all the way up. It doesn't. I can crank the DH500 up all the way and the speakers sound fine ... no distortion ... okay sound. It's loud just not as loud as I would guess it should be. Any thoughts?
I wouldn't mind putting a few bucks into this but not going crazy.
Thanks for the assistance and recommendations!
