Status
Not open for further replies.
1 - 3 of 3 Posts
· Premium Member
Nice looking cable. How did you solder the coax cable to the DB15. I did a cable like yours but the coax to db15 connection are tought. What is your secret?
Bruno
· Registered
Discussion Starter · #3 ·
It is sheer hard work, all the coax are soldered very close to the pins, the housing of the D15 is sawn, and the whole piece is tested before it is moulded into epoxy for life time usage. Then the outer jacket is wrapped with 3M glass tapes followed by adhesive lined heat shrinks.
I read somewhere a forum member did it with 5 L5-CFB, but it sure can't go into that housing.
CH Yeow
1 - 3 of 3 Posts
Status
