I have an nMediaPC case 400BA that holds 3 hdd's and have 2 installed. I'm out of space and need to put a 750GB somewhere. I have GA-M69G-S3H MB and use IGP and use HDHomeRun forTV. Heat is not a problem, but 3 HDD's ,a 1/4" apart does not look good. I have 2 SS Spinpoint 500 and adding a WD 750. I can not get any SMART reading in Speed Fan from the Spinpoints.
Do I have a problem with heat with 3 hdd's?
How can I monitor the HDD temps?
There is no good place to mount a fan, but I could just cram a 60mm fan in between the cables and hdd's. Crazy??
What do you think of my plans and do you have suggestions?
Bob Howell
Bob Howell
