I'm trying to integrate functions from an old Harman Kardon AVR-55 receiver into a Comcast-branded OneForAll URC-1068 remote control. All of the basic functions work fine using device code 0110, but there are a couple that I can't seem to hack out. I ran through all 256 protocols for device 110 (setup + 0 + 0 + 3-digit code), and found the functions I needed which were unlisted / labeled differently in the standard advanced code databases. Those are:
303 video 1 (referred to as vcr1)
307 video 2 (not listed at all)
621 dvd (referred to as VDP... video disc player? maybe?)
The problem is that I need to have control over 2 keys which are very important to my setup: "Dolby Digital" and "Dolby Pro Logic". None of device code 0110's 256 protocols do the trick. The only other Harman Kardon device code listed for this remote is 0189, which seems to do nothing.
Finally, the question - does anyone know where I might find the advanced key codes for these functions, or some method of figuring them out?
