Hi All-
I've set up my H688 remote and it's generally good.
However, when selecting various applications, it often gets lost and ends up on the wrong input! Often this will be when switching to PC input after being on input 1 (DVI).
It seems like it must be toggling through the inputs rather than using direct codes.
This thread, while not answering for a Harmony, seems to indicate the panasonic is a bit touchy if you mix toggling and direct selecting of inputs
http://www.avsforum.com/avs-vb/showt...hreadid=453397
Has anyone else had this problem, and solved it?
Cheers,
Josh
Cheers,
Josh
