Ok...I'm having a problem with the input switching using a Harmony 880 pro. I have a pvr connected via the HDMI1 input, and a dvd player connected via the component1 input. I've tried various configurations of the Harmony remote, but still get the same problem...when I turn the tv on using the harmony to watch either a dvd or the pvr, it goes to the correct input, and switching between the pvr and dvd player works fine. However, if I switch to the harmony's device menu, then back to the activity menu, the input will switch to the tv's antenna input. If I push help when this happens it fixes the problem, but I don't wanna have to push help everytime.
I assume this is a problem related to the way the tv cycles through inputs. So is there anyway to disable the tv's antenna input? or does anyone have any experience with this remote and samsung lcd's and have any advice?
thanks!
thanks!
