Originally Posted by MikeSRC
You're really comparing apples and oranges. The Pronto, besides being a touchscreen, has much more graphics and programming capability than the 880, as well as RF capability. With that you wouldn't need an IR repeater, but if you're looking for one, the Hot Link Pro ( www.hot-link.com ) is one of the best. |
Ok - I get that - and appreciate the info. The pronto is in the $600 range + another $150 for the RF box. The harmony 880 is $230. With the harmony I would need the IR repeater kit.
Question: Is RF that good vs using a wired repeater that it is worth the extra cash? I understand I would also get more graphics and programming capabilities (gotta research how much different these are).
Question: Can I control a Grafik Eye 3106 with the Harmony? I know it is controllable with the pronto.
Question: I checked out the Hot Link Pro. Very nice. Do you know how it compares with the Buffalo system IR repeaters?
I think I need all of these parts to make up the same components in the Hot Link Pro:
8130W* ROUND MICRO IR SENSOR
8191* 4 EMITTER CONNECTING BLOCK (times 2)
8190* 9-VOLT DC 500MA POWER SUPPLY
8186* 50 FOOT EMITTER AND IR SENSOR EXTENSION CABLE
+ 8 emmitters = about $150 (for
Hotlink x-12 is about the same price as the buffalo system made up with all these parts, and you get 12 emmitters (if you need that many).
Can't decide which way to go! Any thoughts?
Confirmed Equipment:
BenQ PE7700 Projector
Da-Lite 120 diag screen
Sony DVP-CX995V 400 DVD changer
Up in the air:
Speakers?
Receiver?
Gary
