1 - 2 of 2 Posts
My 890 pro is out of warranty and the tilt sensor doesn't work consistently. I have to really shake it to get the screen to turn on. Is there a way to clean the sensor somehow? Seems like its not making good contact.
Thanks!!
Thanks!!
Consider the motion sensor as a bonus
You always have the option of pressing "Glow" button just under the screen to light up the remote.
1 - 2 of 2 Posts
