Ok, so I'm have a large closet that will be housing all of my tech and av equipment. I bought a harmony with the hub to control via rf. Everything's working fine, but once I move everything into the closet (hub incliuded) I won't be able to control the TV. I bought a keystone ir target off of Amazon thinking I would have the ir blaster connected to the hub hit the target, then via cat5 send the signal to the 3.5mm jack keystone behind the TV. Then I would plug in an ir emitter from the Jack to the TV.
I hooked it up today and tested it on a blu ray player, but it didn't seem to work. Not sure if I have the wiring incorrect (just used the same colors on the +/-) or if my logic is flawed.
Can anyone provide me some assistance with this? This is the last piece of the puzzle before I can move everything into the room.
Sent from my Nexus 6
