1 - 5 of 5 Posts
· Registered
I just got a bluwave remote for my harmony one. The issue that i am having is that when i am in the activity....only the soft keys work...the square,x,o and triangle....they arrows,play etc don't work. If i just select the bluwave as a device...all the keys work. I have tries relearning the keys, only to find the results the same...am i doing something wrong?
thanks
greg
· Registered
Did you map the device as a Game Device / Nyko / Bluwave ?
When you added the Bluwave device to an activity did you remap the buttons so that UP is "Bluwave UP" and so forth? You shouldn't have to learn anything from the Nyko remote since everything is already in the Harmony database.
· Registered
I have a logitech 880, and just got the nyko remote, just had a quick question.
All I have to do is add this remote as a device, associate it with my already created "watch a blu ray" activity, and tell it to make the 880's play, pause buttons the blu wave play, pause commands......correct?
1 - 5 of 5 Posts
