1 - 2 of 2 Posts
Does anyone know how to create a new device in the Harmony remote software, thats no loaded in the drop down list.
My neighbor has a ADT security DVR system setup and wants to control his DVR. I am sooooooooo used to the MxEditor where it is easy to create a new device and learn the codes. But in the Harmony software I can't find a way to create a new device and learn the codes for it.
Best route is to set it up as similar device by the same manufacturer. He may be lucky and find that the it uses the same IR codes. Alternatively, just pick another DVR, delete all the IR codes and learn the ones from the exisitng remote.
1 - 2 of 2 Posts
