Hey everyone, I'm hoping that perhaps someone else has had this issue too. I picked up the Harmony 680 from new egg a few weeks ago, (I'm told that all their remotes are essentially the same configuration wise though so if you have a different model please keep reading!) I got it all configured up and working flawlessly with one exception.
I should also note that I am using an IR repeater as my equipment is set in the wall so it's not visible from the seating area.
My Denon 2805 (purchased within the last 3 months) will not take certain commands from it. I have taught it the commands from the original remote even (in RAW mode as tech support suggested). Volume works fine but power on, power off and all input selection will not work on actions OR when using the buttons singularly either.
I'd call logitech for support but I'm working durring the days so I wouldn't be able to try anything so I've been using e-mail support, hopefully if no one else here has had this issue they'll be able to suggest something soon.
