1 - 6 of 6 Posts
Hey,
Has anyone had any luck getting a Harmony to work with the STR-DN1000. It appears to not be in their database yet. I have tried picking similar receivers based on their suggestions, but the inputs are lacking. Any ideas or help?
Drew
If the Harmony database has codes for either the Sony 2400ES or 3400ES receivers, they should work to give you most/all the inputs you're looking for.
Has anyone been able to find discrete codes for on and off?
Just programmed my Harmony ONE for this receiver and haven't had one bit of trouble. I'll dig into the discrete codes question at some point, but since the remote only has one button I'm not sure if I'll be able to find anything.
1 - 6 of 6 Posts
