My Harmony Touch has worked fine and I connected it to program it to control XBMC and I noticed a whole new UI for the remote. I ended up having to re-add my devices so that they worked properly. I have everything working except for two problems, one I've always had and a new one.
The new problem is when I select watch tv which uses my DTV receiver, my Panasonic TV, and my Pioneer AV receiver. When I go to the DirecTV activity it controls the DTV box no problem but the volume controls for the AV receiver don't work. Is there a fix for that. Before you ask, I have the Pioneer receiver set as the device which controls volume. It worked before the update but it doesn't anymore.
The problem I've always had is that when everything is off and I select an activity different than the last one I used, the receiver doesn't change inputs. I always had to hit the help button then it would change inputs. How can I make it so that on power up, the AV receiver gets set to the right input?
