Hi,
I recently saw a web site where someone had a bit of a problem keeping plywood glued to Acoustik mat. They had Acoustik mat glued to the sub-floor and then they glued plywood on top of the Acoustik mat--as seems to be the normal practice. The top layer of plywood came up in some places. This has raised some concern with my contractor about using this material.
Has anyone else who has used Acoustik mat had problems with plywood/OSB not staying glued down, warping, etc.?
What type of adhesive did you use?
Did you use OSB or plywood on top of the Acoustik mat?
How long has your floor been in place?
