1 - 20 of 28 Posts
I don't know if it's a rebadged HDHR Prime, but it is a networked tuner. It's enclosed in a completely different case than the HDHR Prime, so it's not rebadged, but possibly repackaged. If it is a HDHR Prime in a different box then I'd be curious to know if it's also DLNA certified.
Originally Posted by Sammy2  /t/1467621/hauppauge-wintv-dcr-3250-3-tuner-cablecard#post_23191555
Looks to be on the same PCB.
You must have bought yourself a set of X-ray specs to come to that conclusion unless you have access to both tuners and compared them side-by-side with the cases open. I'd be hard pressed to believe that Hauppauge would license a tuner design from a competitor, but I suppose it could happen. It also seems strange that it's only available from Best Buy.
The 2650 is made for Hauppauge! by Silicon Dust so why wouldn't this be also?
That said, I suspect it is the same PCB because all the LED's and connections are in the same location as the HDHR Prime. As Silicon dust phases out the current Prime for the 4 tuner model with the h.264 encoder they can get additional sales from their tried and true tuner this way without having to offer two products.. Just a guess. I could be all wrong.
Originally Posted by Sammy2  /t/1467621/hauppauge-wintv-dcr-3250-3-tuner-cablecard#post_23192556
More information right here on avsforum.
That topic is for the dcr-2650. The OP is referring to the dcr-3250. It is a 3 tuner networked box. I have one being delivered today but, I am new to these types of tuners so, I probably won't be able to add much info. As of 2 days ago, the price was dropped to $149 from $179.
I know this. What I was doing was demonstrating to captain video that this Hauppauge! Tuner you are getting is most likely a re-badged HDHR Prime. When you set it up verify if the web GUI looks like the picture I posted above.
Originally Posted by Sammy2  /t/1467621/hauppauge-wintv-dcr-3250-3-tuner-cablecard#post_23219173
Ok. Sorry about that. I'm actually just gonna return it without opening it. The windows media extenders are way overpriced. Also, VZ wans $20 to ship a cablecard. The closest fios cener is 30 miles away.
Originally Posted by foltz61  /t/1467621/hauppauge-wintv-dcr-3250-3-tuner-cablecard#post_23219577
Look on ebay for used Linksys or HP media extenders. You can typically find them for less than $100. Verizon charges you for overnight shipping so if you order it today it will be on your doorstep tomorrow. They used to charge a lot more if they had to send out a tech to install the cablecard so consider it a bonus.
Let me understand this. You are not going to use the CableCARD tuner because of a shipping charge for the CableCARD and you are not going to use an extender because it cost too much but are willing to pay rent to Verizon month after month for their DVR's?
I suppose it takes about 30 months to recoup the cost of an extender but I need something to stream local media anyhow so why not an extender?
Originally Posted by foltz61  /t/1467621/hauppauge-wintv-dcr-3250-3-tuner-cablecard#post_23222399
Yup. $400+ for 3 extenders. Then I'm sure my computer will be too slow to run 3 extenders. So that will need upgrading. If the exenders were closer to $50 each, I'd do it.
For me the pay back was pretty quick, especially if you go the used route on an XBox 360. Cablevision charged us $17.98 a month per DVR ($8.99 per cable box, then $7.99 for DVR service). So even if I had bought an Echo at $179.99, its only a 10 month payback. They also attached a $5 'extra drop' charge for having more than 2, so it was even more economical.
Another thing that stops me is, how long will it be until this setup would become unusable? I didn't say obsolete because I don't need the latest and greatest. I actually pay $40 a month for a multi room dvr and 2 HD boxes so, I'd be at about 14+ months just to break even. That's without a pc upgrade. RAM is fairly cheap now though.
1 - 20 of 28 Posts
