Status
Not open for further replies.
1 - 7 of 7 Posts
I have a 32 meg bin file, that is titled UTV3.7.bin, I got it by buying a cd off ebay that had the image. And now, I just registered winhex and also cleared a 40 gig drive that had 3.5 on it. I want to copy this 3.7 onto it, but I don't know how.
I have been able to see the drive in winhex over a usb2.0 enclosure, and would like to try it this way. It should work just like if I connected it to an ide cable, right?
I probably just need the right numbers for winhex clone to go from a file to a drive. Anyone know the right numbers to punch in?
Here is what the file looks like in winhex at offset 0:
Offset 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
00000000 04 00 10 00 00 00 00 00 3F F2 FA BB 40 00 00 0E ........?òú»@...
00000016 3B DF 00 0E 6E 3A 00 00 00 00 00 00 00 00 00 00 ;ß..n:..........
00000032 00 00 00 00 46 53 4E 6F 00 00 00 00 00 00 00 00 ....FSNo........
00000048 20 00 80 CE 00 30 00 00 00 00 00 00 00 00 00 00 .€Î.0..........
Originally Posted by rocket
***I probably just need the right numbers for winhex clone to go from a file to a drive. Anyone know the right numbers to punch in?
Herculito's hearsay is here . :eek: :eek: :eek:
Discussion Starter · #3 ·
ALRIGHT!!!!
I did it. So, for the record, here's what I had to do.
First, I had to copy the utv3.7.bin file to my HD and rename it to utv3.7.dd so winhex could see it.
I plugged the freshly cleared drive (by using my half broken utv to clear it) into a usb 2.0 enclosure. I'm running with w2k, and I launch winhex. I find that most of the drive is zeroed, but something keeps writing to block 0, with what looks like a MBR record. But everything else is zeroed.
I go to the sector mentioned, 631811 and do the clone as it says. The biggest problem I had was in figuring if the values, like 13480600 was in hex or decimal, since it has no hex a-f chars. But by reading all the message over and over I was able to conclude this was hex.
But even after I zeroed block 0, I found that on telling w2k to unmount the drive, after I loaded it up again to look, it had block 0 filled again. Finally, I just zeroed it using the in-place mode, and after a few seconds pulled the usb cable. Then when I reloaded it, block zero was nearly zero, just one number still set. So, I zeroed again, pulled the cable, and took my chances. Well, I guess even if one number in block 0 is not 0, not a problem.
It came up beautifully, so now I got my spare setup with 3.7.
Thanks for the link.
Discussion Starter · #5 ·
I have no way to share the file, that's why I bought it for $5 off ebay. Considering that the winhex license cost me $52, it was a bargain. Sorry.
I see that there are a couple selling on ebay now, but the price with shipping is about $14
try 5801326638
Lots easier than trying to find one online.
1 - 7 of 7 Posts
Status
