1 - 7 of 7 Posts
So my room is about 18x14x8, but it's got a weird shape to it. TV is on wall where chimney shaft is, then next to it is a closet and then it leads to the end of the room where there are three large windows that are angled next to each other. I've been very happy with my set up for a while, but one thing that has always bothered me... is that the room has an echo to it. If I yell or clap very loud, I'll be able to hear it. So I can imagine that it wreaks havoc when listening to anything through my system.
I just bought a Rythmik LV12R and with the purchase, it got me thinking that I want to get the most out of my set up. I am a total noob to treating a room and was wondering where I should start. What are some things that I need to think about or look at to see what I can do to fix it? Is it even reasonably fixable? Since it's a living room, I don't know if there'll be much I can do, since my wife won't be happy about it...
My current set up consists of 2 x Energy CF-50s, a CC-10 center, 2x CB-20s for surrounds and a soon to be replaced Bic H-100 by the Rythmik.
Any guidance you guys can provide would be great!
Thanks in advance!
Banned
Originally Posted by Derko  /t/1499225/have-a-bit-of-an-echo-where-to-start#post_23938751
Thanks in advance!
What you do is walk around the room and approach all of the wall segments, etc. Clap a few times at each location and see if the clap comes back at you from that piece of wall.
Once you identify the pieces of wall that are giving you back talk, apply some generic sound treatment, say one or more 2 x 4 panel(s) of 2" Corning 705 sound insulation with a 2" space behind it.
Here's an article about DIY sound panels that you can take some ideas from:
http://www.instructables.com/id/Make-accoustic-panels-for-your-recording-studio-or/?ALLSTEPS
You can find these panels or something like them ready made:
http://www.acousticalsolutions.com/acoustical-wall-panels
http://www.audimuteacousticpanels.com/acoustic-panels
http://realtraps.com/products.htm
Google is your friend!
Banned
Clapping your hands is not a proper test. Your speakers are not 3 feet from your ear
. Have someone else clap where the speakers are and sit where you normally sit and see if it is still there. If it is, yes, your room is too live and while it would sound good with some content, hearing dialog in movies and such would be harder, etc.
The solution is to put more objects in the room that woudl either scatter or absorb the sound. They do not need to be in conflict with your wife. Just give her some money to buy a throw rug if your floor is bare (and thick padding under it), bookshelves, sofas, curtains, etc. They all help. Here is a nice example of how much from Dr. Toole's book where it shows what happens to "RT60 time" (fancy term/measurement for the "echo" you are hearing) as you add furnishing. As you see, they all help to reduce the reverberation time:
Discussion Starter · #4 ·
Originally Posted by arnyk  /t/1499225/have-a-bit-of-an-echo-where-to-start#post_23939066
I'm not at home now, so I can't do it at the moment... but I do have the rear wall behind my couch, only 10 inches away. I also have very low voice from my center channel, which I've assumed that reflections from the rear of the room is what the issue is. Would maybe that be the very first place to treat?
Also, is there any cheaper options to try? It seems to me that around $300 bucks is a lot per panel.
Originally Posted by amirm  /t/1499225/have-a-bit-of-an-echo-where-to-start#post_23939427
Yes, and not only that, hand claps don't have any bass content to excite room modes and ringing.
--Ethan
Discussion Starter · #6 ·
I can't believe I missed your post! So... I did try clapping at the walls and honestly, ALL OF THEM were bouncing sound back, so I just gave up.
Now that I read your post though...
So my floor is carpeted, I have two sofas and the walls right behind the couch have a very large frame of a ton of pictures my wife has throw in there from over the years. Then the rest of the walls have for the most part something on it, but mostly frames.
Would you suggest adding another rug on top of the carpet? I have that very short flat carpet type and then maybe throwing up a bunch of frames instead of just one behind the couch? I've also got a couple of bookcases with games, books, and DVDs. Then 3 ottoman's throw about the room. Then the entrance to the room is two very large doors that I put there to close the room off. Before it was wide open to the entrance to the house. The doors are from floor to ceiling and around 42in wide each... I guess I could try something up on the doors too for breaking up reflections.
I'll post some pics of the room later today to give you guys a better idea... my sub comes in tomororw and I'm reading and looking into EVERYTHING sound related for my room right now. Can't wait!!!
Banned
Originally Posted by Derko  /t/1499225/have-a-bit-of-an-echo-where-to-start#post_23942611
In a sense that's good news - you can put absorbtion anywhere and not waste it. ;-)
The surfaces you want to work on first are probably the ones that are opposite and close to the sound sources.
Carpeting is often poor sound absorbtion because it has to be thin so that you can walk across it without getting bogged down. Putting absorbtion on the ceiling accompishes similar benefits and you have a lot more freedom there because you don't walk on it (I hope!).
I'll post some pics of the room later today to give you guys a better idea... my sub comes in tomorrow and I'm reading and looking into EVERYTHING sound related for my room right now. Can't wait!!!
Pictures and drawings are good!
1 - 7 of 7 Posts
