Status
Not open for further replies.
1 - 8 of 8 Posts
I try to turn my philips dvd player in pal progressive with the procedure in entering a code p081000000000 and my philips now is blocked!!!It keeeps on seraching for a dvd and then turn off than turn on then turn off I don not know what to do I am completely upset.
Please help me!!!
Hi, bannani,
Did you see the p-code of your Q50 before doing the modification? Is it possible for you to fall back to the original configuartion by entering 'PPP000000000' where PPP is the original p-code of your Q50.
Discussion Starter · #3 ·
yes i note it it is p66 but the player seems to be like in a circle. It turns on trying to find a dvd disk or something else and turn off immediatly and so on. I try to type my P66 but nothing appear on the screen. But the player has nothing to do with my remote control.
If it can help I noticed that the firmware was 4.15c
I am desperate!!:(
Discussion Starter · #4 ·
WOW now I succeed in entering in the menu of the dvd player and the p code chenge to 66 into 81 which is apprently the code for region 3.
Now I have to follow the second step and make it region free in entering rc6 code.
I let you know the steps of my hack.
hanks for your help Kwokian
Discussion Starter · #5 ·
I succeed in entering the rc6 code but nevertheless my dvd don t want o play any disk. I keeps on turnin the disk with a lot noise without any video except its mires.
Could what shoul I do?
Discussion Starter · #6 ·
Ok, I succeed in reading region 1 and 2 dvd. The hack succeed.
Thanks for your advise.
But come dvd blocked. Does it comes from the firmware. it is the 4.15 c in comparison with the other playes which they have the 4.15i.
Hi Bannani,
Where did you buy your Q50 in the EU? I thought the EU Q50s didn't have prog scan.
1 - 8 of 8 Posts
Status
