1 - 5 of 5 Posts
· Registered
I've only ever used tubes from an 880/881/895/900.
Not sure if other consumer RP tubes will work, but since the tubes used in the set are low end tubes, it's conceivable that other RP tubes MIGHT work, esp. those used in a Zenith RP set.
· Registered
Discussion Starter · #4 ·
they look nearly identical to the PV4663RK tubes for the old zenith projo sets.
only difference is they have a slightly longer neck to compensate for the adjustment rings on the bottom, which the zenith RPTVs i worked on never had..
1 - 5 of 5 Posts
