1 - 3 of 3 Posts
· Registered
Recently bought a 2006 explorer with a satellite antenna. However, I can't get an eSN code (tried direction from manual and Sirius operator) and Menu/Aux buttons on radio suggest the car is not fitted for Satellite. Former fleet vehicle. Any suggestion? The antenna was installed just for show? Was sold with sat option.
· Super Moderator
Entirely possible that the trucks ordered for the fleet were all of a style or package that came off the line with satellite radio, but the contract specified no satellite. It's easier to switch the radio for 20 or 30 trucks than make a run of a certain style truck with a different roof. So, yeah, it probably has the antenna or at least the housing without the radio. Kind of like when you get a dashboard and you can tell where a switch or gauge WOULD go, but there's a blank insert instead. Easier to put in the insert than to design a bunch of different dashboards.
Doc
· Registered
Some cars have a separate tuner in them. The previous owner may have taken that tuner out, also its possible sat radio burned out or a fuse burned out(some fuses are on the tuner and not in fuse box area)?
previous post by DrDon is very possible and logically a good answer.
1 - 3 of 3 Posts
