Originally Posted by
RyanHomsey /forum/post/20789610
A few questions:
1. Sometimes when I make massive changes for the color via its tint/color control it does not reflect in the x and y values shown in HCFR, why? I would think when I can visually see the tint changing radically, those values should always change significantly... yet sometimes they do not change at all, why?
The main reason that concerns me is because my goal, initially, was to make as big of changes I needed to get as close to the x,y values as possible. On my first run this yeilded my red at a 'color' point very high. As soon as I put on some reference material I knew it was much too high. Does that indicate I have a bad meter? Am I missing something?
2. As I understand it the x and y values signify a colors saturation and hue. So, I should get different values when displaying the 100% saturation red over the 75% saturation red, correct? Because I dont, the values are the same.
The reason I ask is because I noticed another LG LCD owner here noted an issue with the CMS in his LD550, a very similar model. He outlines his method in this thread:
http://www.avsforum.com/avs-vb/showt...0#post18868120 and said
I tried his method, and was able to achieve the x,y points he directed to except for blue. But I found, after measuring, that the results yeilded were significantly off. I basically had to take all the saturation out of red to hit his values. Obviously didnt work for me.
I feel like I'm missing something. The grey scale was so easy and accurate. I'm finding the CMS to be quite frustrating.
I attached my HCFR file in case it might help you identify my issue.
