1 - 5 of 5 Posts
I have a Mitsubishi HC1600 projector that i would like to hook up to and control through my Main Lobby Server. The projector has a serial port on the back but the manual says its for "technicians use" whatever that means. My question is does anyone know anything about this model? Will i be able to control it through the serial port? All i really need to do is send a power on and a power off command.
Thank you
if u can get service manual for a mitsu it should tell you what serial port does there are afew commands it can do not sure if it can shutdown.check online if u can get a service manual for say hc1500 it should be similar.
Discussion Starter · #3 ·
yea i have the manual that came with it. all it says is that its for service use. When you say the service manual, are speeking of something different than what came with it? Do you think id get anywhere with Mitsubishi tech support?
thanks by the way
1 - 5 of 5 Posts
