Does anyone know where i can get a replacement color wheel for the hc3000? Or know of any suppliers i can checkout?
Any information would be great.
Originally Posted by Sheridan1952 /forum/post/16806006
You're not going to like this. I just checked and the color wheel for the Mitsubishi HC3000 is about $350. That's more than twice some other manufacturers.
Originally Posted by blindbartimaeus /forum/post/17990177
Return it if you can. I have thouroughly looked. IF...IF you can get someone to sell you the part it is about 225-250 and most won't sell it. It will run you 400 to send it to mits to fix it.
