Originally Posted by smokarz /forum/post/21738020
Hi John, do you think there will be a new release this week?
Originally Posted by 703 /forum/post/21735413
What I've found is that the scroll bar doesn't really scroll down to the last row of the table that shows "greyscale" and "primaries / secondaries" etc.
E.g. can't see delta luma in the primary/sec table.
Originally Posted by JohnAd /forum/post/21735442
Yep, drives me mad tooit's on the list, I am focussing in driver issues for now though so won't get fixed in the next version but probably the one after that.![]()
John
Originally Posted by jdbimmer /forum/post/21739584
There are 2 workarounds for the scroll bar/hidden rows (see attached pic):
1. (Easier) Click the down arrow next to the Editable Data box until all the rows are displayed.
2. You can resize each row like you would in Excel by clicking and dragging the row lines in the leftmost column until everything fits.
Unfortunately it doesn't save these changes so you have to do it everytime you create or open a chc file.
Also, I ran a quick test on my PC monitor using the Argyll drivers and an original Monaco Optix (not the DTP94, the C5-ish? model) and it worked. I'll provide more detail when I have time to measure my plasma.
Originally Posted by CalWldLif /forum/post/21739622
wow, if I am reading that pic right, that is a perfect gray scale.
what monitor is it?
Originally Posted by Bluescale /forum/post/21737264
I have a 65ST30, and the measured values definitely jumped around like crazy when I got to 50ire. Still, I'd recommend doing a test run, just to see what happens. You don't have to make any changes.
Originally Posted by JohnAd /forum/post/21737423
But yes worth getting some practice in with the software, and start collecting the UI bugs.
Originally Posted by 65Cobra427SC /forum/post/21739870
Preparation was fairly easy but I wasn't sure if I was supposed to calibrate my meter or not... I tried, but nothing happened when I clicked on the "Calibrate Meter" button so I moved on.
Originally Posted by Bluescale /forum/post/0
The Display 3 does not require calibration.
Originally Posted by jbfunk05 /forum/post/21740592
Using dispcal just as an xyY readout I can confirm that the instability at low IREs is dramatically reduced.
Second, I have always been unsure about which switch to use for a plasma, CRT or LCD, but thought the overall consensus was CRT. Is that still true with the i1 Display Pro? I know that some of the older colorimeters reportedly had issues with infrared emissions from plasmas and would over-report red in any mode, but it always seemed like CRT mode was the closest to accurate. I'm hoping the i1d3 doesn't have these issues, but in any case the ability to use edr/ccss files seems like it might mitigate the effect. On that note, I would love to see the Argyll i1d3 ccss capability integrated (which I know you had mentioned before - just thought I'd add a plus one). Hopefully someone with access to a nice spectrophotometer will post some ccss readings of a plasma to work with!
Originally Posted by dlarsen /forum/post/21740557
I tested the HCFR DIY V5.1 sensor and it selects, connects, and comms AOK. Win 7/64.
Originally Posted by wl1 /forum/post/21740526
I forgot to mention in my previous post, I pressed the calibrate button, but nothing seemed to happen (i1Display2). The old process would ask for a calibration prior to running the first greyscale. And involve a couple of dialogue boxes with confirmations.
Originally Posted by JohnAd /forum/post/0
Most versions of the display 2 don't need to be calibrated in LCD mode, the x-rite i1 sdk code allows calibration for all meters but for lcd mode it doesn't actually do anything. If you have one of the older version it will detect that and ask you to place the meter on a flat surface to calibrate as the old hcfr did but that only applies to earlier revision of the meter.
In crt mode it isn't really a calibration just a refresh rate lock.
John
Originally Posted by JohnAd /forum/post/21740614
As we get to later versions the button will be greyed for those meters that don't need calibration.
First, I have a Samsung plasma and can also confirm the erratic readings starting at 50 IRE downward. I noticed you mentioned before that the plasma issue might be fixed in the latest Argyll code so I grabbed the dev source from the Argyll site and compiled it. Using dispcal just as an xyY readout I can confirm that the instability at low IREs is dramatically reduced.
Originally Posted by dml1333 /forum/post/21741533
JohnAd,
This is debug testing for opening older files: I wanted to test Wl1's issue with opening older files. I have no issues opening my old .chc files generated with ColorHCFR 2.1 with my DTP-94 (X-Rite drivers obviously). But when I open Wl1's .chc file included in his post, AND at the time I have NO meter plugged in, I get an error from the Argyll code "No meter found - Create Argyll instrument failed with severe error". It appears that the Argyll code really wants a meter plugged in even when I just want to view the .chc results.
