Not sure where to post bug reports - apologies if this is not the correct thread!
In any case, HFCR 3.0.4.0, installed on a Dell laptop model D620 running WindowsXP SP3.
I have this installed on 3 different laptops, 2 of the D620's and one a D630.
On one of the laptops (my main one!) HFCR crashes when going to the "Select Sensor" window. There is a brief delay, then HFCR exits.
The also occurs if I attempt to open an existing .chrc file I had previously saved.
I have attached the minidump and stderr.log files. In looking at the stderr.log file, it appears to be some kind of issue with one of my USB devices. It attemps to open a device called "NmeaDev" then reports "SEH Exception Occured".
I have tried to disable various USB devices - Bluetooth, and some devices from a Sprint aircard. There are less devices being accessed, but in the end the access to the NmeaDev seems to crash HFCR.
JGrana
HFCRcrash.zip 107k .zip file
