Originally Posted by
Make73 /t/1393853/fork-of-hcfr-started-whats-needed/1110#post_22701473
http://www.drycreekphoto.com/Learn/Calibration/MonitorCalibrationHardware.html
Instrument : i1Display Pro/CM Display
Units Tested : 13
Mean Delta-E 2000 : 0.4
Max DE-2000 : 1.6
Seems that there´s not so much variable between different units (when new).
Many have reported redish white balance without matrix.
Zoyd wrote earlier that using Matrix is more accurate than without it.
Of course you don´t get reference meter with using matrix which is made to other unit , but point is that you can get closer with that.
Zoyd made his one with i1 Pro 2 meter and kjgarrison´s matrix was delivered from Chromapure with meter. Those two matrixes are almost same, at least result is almost same. Only difference what I got was W/B High B +/- 1
rahzel reported same kind of results:
http://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed/840#post_22311630
However I used that and get rid of redish white.
Also color temperature difference is almost 500K, without matrix picture is too warm.
Of course it also affects to colors, CMS settings was also pretty different than without matrix.
You don´t have to use that, it´s there that you can try
Try to set one preset without matrix and other with matrix so you can compare those.
Thanks to zoyd and kjgarrison for sharing their matrixes.
Here is picture when matrix was entered and made grayscale remeasurement, as you can see it´s quite redish:
