Couple questions, I am going to profile my ID3 with my EFI 2000 (i1Pro2), and had some questions about the post in this thread since its a little older. Also I am having issues getting HCFR to recognize my meter, I found a post saying meters with a model number of XR-UF are stripped down OEM meters and have issues and need a flag changed. But my meter has a model of EFI-ULZW , which seems to be a full i1Pro2. JVC Autocal and Xrite software saw the meter fine (uninstalled the xrite software to avoid conflicts). Anything I need to do to get it to work other than drivers which have been installed?
Found the issue, xrite driver was overriding my argyll driver. Also, now that I have been reading, am I better off using DisplayCal or HCFR to profile my ID3 with the i1Pro2? I have never done either....
Below is the post I was using for the profiling with HCFR:
1. Set up a calibration DVD to display the primary (red, green, blue) colors and white windows sequentially.
Use a 10% window at 100% amplitude. <-----Can I use full screen patterns for this since I will primarily be using the meter with JVC Autocal correction?
2. Put both the D3 and the Pro on the TV panel so the meter sensor holes are vertically in the center of the window and right next to one another. (Or you can do each meter sequentially so that both are reading the same area.) <-- Assuming this doesn't matter for projector, just use my usual 2ft distance
3. Set up HCFR for the i1 Pro meter and do a normal sensor black level calibration (Measures/Sensor/Calibrate...)
I do not see this option, is it talking about the sensor calibration using the white swatch that comes with the sensor?
4. Run the primary colors and the white windows reading the data with HCFR set up for the i1 Pro meter. Save the run as something like "pro meter calibration.chc"
Is white windows just a grayscale run?
5. Set up HCFR for the D3 meter and do a normal sensor black level an 80% white level sync calibration (Measures/Sensor/Calibrate...)
Where is this option, I do not see anything under measure > sensor with the ID3 hooked up?
6. Run the primary colors and the white windows reading the data with HCFR set up for the D3 meter. Save the run as something like "D3 meter calibration.chc"
7. Display the i1 Pro results on your computer and check the "Reference measure" box in the upper right hand corner.
8. Display the D3 results and click Advanced/Meter correction file/Create using existing reference measures.
9. Display the D3 results and click Advanced/Meter correction file/Save meter correction file... Save it with a name like "D3 calibration matrix 08-17-2014"
