Thanks for the tips.
Read that reducing cell light affect postively to brightness pops ( ABL behavior ), that´s why used lower cell light and higher contrast.
Maby try that at next calibration, after break-in period. So does it give higher ANSI white if you do it the other way around?
Do you think it´s worthwhile doing calibration with 75% saturation windows in this case? I suppose then 100% is off?!
Samsung PS64E8000 Movie mode calibration.zip 60k .zip file
Originally Posted by zoyd /t/1393853/fork-of-hcfr-started-whats-needed/1710#post_23147075
You're welcome! Nice looking calibration, I would recommend you use cell light 20 and reduce contrast to get your desired peak white because that will give you brighter response during scenes with a lot of white content (hockey etc.). There is not much you can do about the red non-linearity except calibrate using 75% saturation patterns.
