1 - 3 of 3 Posts
I was wondering if anyone can help me with an issue I am having. When I select RGB Full as the pixel format it works fine for 30 seconds to a minute and then automatically switches itself to RGB Limited.
Has anyone experienced this with their 6670 or any other AMD card? Thanks for any input.
Also, I have tried two different Catalyst installs. 11.8 and 11.7 both have the same issue.
have you considered it could be your tv or your monitor? if it doesnt support Full RGB, it will revert to limited automatically. I have a 6570 and it works fine. and i have mine running through my Onkyo 805 AVR.
1 - 3 of 3 Posts
