1 - 5 of 5 Posts
· Registered
Originally Posted by LITEGUY2004 /forum/post/0
Is there any drop in quality if you use the horizontal shift on the hd 70?
thanks
John
Shouldn't be - all you are doing is shifting pixels.
· Registered
Originally Posted by Tyro /forum/post/0
Can't find the article right now, but if I remember correctly, vertical and/or horizontal shift causes moire, or blurring.
You are thinking of lens shift.
· Registered
I hope you are talking about a picture (pixel) shift and not using the "Keystone" adjustment. Using the keystone adjustment will effect picture quality. The more keystone adjustment you use, the more distortion will be introduced.
1 - 5 of 5 Posts
