HD-A2 Red Light?
746 Views 4 Replies 5 Participants Last post by  geko29
Just a question- When I press the button on the A2 the light around the button turns blue and the power turns on. When I press the button again, the light turns red, and power turns off. But even though the unit appears to be off, the red light stays on...
Is the red light around the power button supposed to stay on even when the unit is off?
Just curious,
thanks,
david.
1 - 5 of 5 Posts
Yes. The red light indicates the unit is in a standby mode.
It's so you can find the button in the dark
See less See more
And if you kill the power at the wall or unplug the player it takes approx 20 seconds for the red light to go out.
Unless you push the power button, then it goes off almost instantly.
1 - 5 of 5 Posts
