Status
Not open for further replies.
1 - 2 of 2 Posts
I would like to know if there is anyone in Renton Washington has got the HD Antenna? I want to buy Terk TV35, but I really don't know if it's going to work. Since there's HDTV-TV60 antenna which is supposed to be the best antenna to pick up HD signal (According to the Good Guy's saleman), I don't know if I should buy the TV35...Please help and give me some advices. I appreciate your help.
Don't believe the salesman at the Good Guys. Please search this site on UHF antennas and you will find dozens of great threads. I have read nothing good about Terk antennas. That $300 Terk beauty can be beaten by a $30 Rat Shack antenna. Channelmaster is a favorite of most on this site. I am using a AntennaCraft MX-U59
Check here for the type of antenna you should look for and where to point it from your location. I use a rotor.
http://www.antennaweb.org/antennaweb/
great site with local HD programming guide.
http://www.titantv.com/ttv/programming/content.asp
Just don't buy that Terk antenna. Remember what rhymes with Terk
Good Luck
Rick
RJW
1 - 2 of 2 Posts
Status
