I just bought a Canon HG20. My main purpose is to record guitar instructional videos indoors. I did some tests today and the video seems fairly noisy (i.e. similar to the artifacts you see in photos shot with low light and long shutter speed). Also, the large number of pixels on a small sensor I suppose implies noise as well. I am just wondering if I jumped into HD too quick. Would lower resolution camcorders with larger sensors produce less noise? Also, would a slower frame rate reduce the noise?
Granted, my lighting wasn't ideal today. The room was lit by two overhead 75 watt soft white lights. The room is only 12x12x9. Should I expect vast reduction in noise once I get proper lighting (i.e. 3 point lighting)?
thanks,
brian
thanks,
brian
