Status
Not open for further replies.
1 - 1 of 1 Posts
I have a Panasonic HD receiver for Direct TV and OTA channels
and use NEC doubler's output ( RGBVH 5 BNC's) to the same input on Zenith projector.
NEC will not pass HDTV signal so I have to run Pany out to Zenith directly for HD channels and back thru NEC for other channels.
What solution would you recommend so I can avoid switching the cables ?
NEC doubler has a component and VGA 15 pins ports, but they do not pass HD bandwith.
Any help will be appreciated.
Mike
1 - 1 of 1 Posts
Status
