I've been toying with picking up the HD-DVD add-on but wanted to know what I'll be able to do and what I won't so I know its true value to me. I have a 65" Toshiba rear projection CRT that's 1080i native. The 360 looks *great* on it connected using component cables. I don't have the ability to connect using VGA because there's no VGA port on the TV and my DVI port only does DVI-D (evidently you need DVI-A/I to use DVI-to-VGA converters).
So given that setup, will I be able to watch HD-DVDs in 1080i over component? If so, is it sending the native 1080p signal interlaced for my screen? Also, I'm pretty sure I can't use it as an upconverting DVD player without VGA, so that's a bummer but not a total deal breaker.
Also, where are folks getting HD-DVD content? Netflix?
Scott
Scott
