1 - 7 of 7 Posts
Looking forward to getting the Toshiba A2 player soon. Quick question before I do though. I will be using it with a front projection system (Panny AX100). So would I run the HDMI from the Toshiba into my receiver and then from the receiver to the projector? That is the only way I can think of to do it. Will the receiver somehow degrade the image because the HDMI is running through it or will it just "pass it on" to the projector? Any input would help. Thanks.
Discussion Starter · #6 ·
The Yamaha that I have (or will soon have I should say) is proabaly the RX-V661. Are there other Yahama receivers that have HDMI on them too? What will the HDMI on the one I listed and any others do?
1 - 7 of 7 Posts
