1 - 7 of 7 Posts
I bought the Philips 40" LCD model # 40PFL3705D. When I watch an HD show or BD the picture looks weird, the foreground isn't blended in w/ the background, it looks like obvious green screen, its the "soap opera" effect. I can see the different layers and its getting annoying.
I've googled this and seems like a lot of people have experienced this, but there isnt any fix. I turned off 120hz and it didnt do anything. I played with the different viewing modes ie: sports, games, movie, etc and not much difference. Online specs says this HDTV has "Pixel Plus", but there isn't an option for it. Also "picture settings" menu is limited, so there isnt much I can adjust.
Anyone have experince w/ this? Pls help.
You didn't turn off the 120hz because you can't.
You turned off the motion processing. However, with the motion processing off, there is no way the TV is displaying the "soap opera effect" so it must be another problem that is causing what you see. Hopefully somebody will have a solution. Good luck.
The motion processing is 120hz...
There is no tv out that is native 120hz, 240hz etc they are all native 60hz,
50hz for me though
All 120hz sets do is double the frame count and insert false frames to smooth
motion. Broadcast material is broadcast at 60hz or blu ray 24hz so there would
be no point in a 120hz tv any way. Its like having a full hd telly just for watching
sd 576i content.... wasted pixels.
As for the problem your suffering what backlight setting are you using try
turning that down as that is like shinning a light it will just make faults more
noticeable. Also what sharpness setting as this can make things pop if set to
high which can have a negative effect.
You say hd or bd so it doesn't happen with sd content?
Discussion Starter · #6 ·
Thx
Yes, only on HD and BD, not SD.
Originally Posted by HaRd2BeAr /forum/post/20586600
Don't get were your coming from here?
Me?
Me?
No not you
If not on SD maybe it is something to do with the sharpness
making the picture pop to much.
BoilerJim get what you are saying now
Still doesn't quite make sense to me but to much going on in my head right
now anyway
1 - 7 of 7 Posts
