HD to 15pin input question
767 Views 2 Replies 3 Participants Last post by  DaGamePimp
Is there an adaptor or box that can be used to get a HD signal (component or HDMI) into a 15 pin RGB input? My Sony vpl-px11 has two 15 pin inputs and is supposed to handle a 720P or 1090i signal but was wondering the best way to do it.
1 - 3 of 3 Posts
Yes. You're looking for an HDMI to VGA converter. I'm sure someone will pop in here with a recommendation. Or you can just bounce on to Google and start reading reviews...
Look for an HD Fury
http://www.hdfury.com/
Jason
See less See more
1 - 3 of 3 Posts
