Status
Not open for further replies.
1 - 3 of 3 Posts
Newbie question:
I will be placing an order for a Mitsu 73411 and need to purchase a DirectTV/OTA HDTV tuner. Is there a reason to stay with Mitsu (SR-HD500)or should I purchase something else, like the Sony HD200? Other suggestions would be appreciated.
Thanks in advance for your help.
Paul
Promise Module?
The Mits HD500, Tosh DST-3000 and Hughes E86 are all the same unit, which is made by Hughes. If you are going this route you can save some $ by getting the Hughes E86. Seems to be a very good unit and now some good deals.
The newer generation of DirecTV HD Stb's include Zenith 520 and Sony HD200, which are the same unit made by Zenith (or their parent co. LG) and you can save some $ by getting the Zenith. The other new gen box is the Samsung T-160.
If you go to the HDTV Hardware section of this forum there is a FAQ that has info on all these boxes.
1 - 3 of 3 Posts
Status
