I am able to see the 1080i VGA output from the HD100 on a VGA resolution computer monitor. I have an old IBM 14-inch monitor which can only display 640x480 and it shows the 1080i output. How come this works? I thought you needed a monitor that supported 1920x1080 resolution to see any picture at all.
The picture is kind of squished into the middle of the monitor however. Is there any way to unsquish it? What is the minimum resolution a monitor must have to see an HDTV signal properly using the VGA 1080i output? Thanks.
Will
Will
