Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
When tuned to 9.1(signal strength in 80's), the HD100 will change to 9.2 intermittently. Display still reads 9.1, but I see 9.2. Sometimes lasts for a few seconds, sometimes longer.
I'm using a UHF/VHF amplified indoor antenna.
Sometimes I can see 9.3 when tuned to 9.2, but less frequently than seeing 9.2 on 9.1.
Anyone know what's going on?
Its a known HD100 problem with some stations that are multicasting. SONY says they will have a firmware fix soon to be delivered via DirecTV satellite. You should call Sony and report it anyway though, the more reports the higher the priority.
Tony
1 - 2 of 2 Posts
Status
