PJ is ECP4100. The PJ currently has HD6C lenses on it. Will color corrected HD-144's fit? Will I notice a large difference in quality (is it worth the trouble)? BTW - I will be changing out all the coolant in the tubes (new stuff is all clear), if that makes a difference.
Also: I've heard the HD-144's have a shorter throw distance than the HD6C's, but cant find specific info - exactly how much shorter is it? (will I need to move my PJ more than a few inches for the same size screen?)
--Eric
--Eric
