Comcast cable is apparently using the Motorola HDD 200 box to provide HDTV component output from the DCT2000 converter box. You can see the back panel here: HDD 200 Back and the front here: HDD 200 Front .
The data sheet says the S/PDIF connector is RCA Phono.
How do you get AC-3 digital output from a RCA Phono plug into a receiver, like the Denon 3802?
Do you take the coax S/PDIF feed off the DCT2000 instead of the HDD 200? Do you get the HD feed then, or does it matter for audio?
