I had a very strange problem with my Diva this morning.
Diva completely blocked :
What has solved the problem is disconnected the 3 HDMI output cables (TX0 : TV / TX1 : Projector / Audio Out : soundbar). I had once again the problem when reconnecting. Then I diagnosed that it was the HDMI connection at Audio Out that was causing the problem.
I replugged everything and the Diva restarted ok. No problem since today... What happened ?
Do I have something wrong on the Diva HDMI Audio Out connector ? That's my fear. My HDMI cable is brand new and is working (Diva Audio Out to HDMI IN Soundbar).
Thank you for your support.
- Was able to connect via the webserver
- No input entered in the web server was taken into account or processed
- Toggle switches : no action / oled screen seemed frozen
- All the devices connected (IN and OUT) were not powered (standby mode only for the TV / usually this TX0 edid is recognized by the Diva when TV TX0 in standby mode - here no input/output detected on the Diva - Everything empty)
- Last but not least : unplug/replug power of the Diva did not solve the problem (did it several time / no change)
- I unplug/replug power also of ALL the devices connected to the Diva => no change
