I am looking for help,
I would like to know if you know any product to use with Philips Hue hdmi sync box.
The problem is that when i use my nvidia shield pro watching any dolby vision content, the Philips Hue lights do not work well... they go crazy... i was looking a product where I could conect the nvidia shield tv pro, and then 2 outputs. One should go directly to my lg cx 77 oled earc tv and the other output to philips hue sync box (but this signal must be no hdr because the philips box goes crazy with hdr content). Then the sound goes to my soundbar by earc.
My english skills are terrible sorry.
I was thinking in hd fury diva 4k device, because in some forums they say that it works... the 4k diva has a downscaler output right? So if connect the nvidia shield to input 1, then main output to my tv and the second output (the 1080p one) to the philips sync box... the sync box will recognize a 1080p signal (sdr) so it should work with any issue, isn`t it? On one hand if diva can convert a 4k dv signal in a sdr 1080p signal in one output and in the main one keeps sending the main source in 4k dv... i don`t find which could be the problem... would you have any idea?
I apreciatte your help,
Thank you,
Thank you,
